Previous in Forum: Quality and Purity   Next in Forum: Metallurgy Specification - Bronze and PTFE
FRP Profile Testing
08/11/2011 8:49 AM
I have the need to check an FRP profile (round rod) for internal microvoids in line during production. The profiles may be as large as 5" in diameter. We currently use a post-production water bath ultrasound system. This works but is very inefficient, labor wise. Any thoughts?
Good Answers: 101
Re: FRP Profile Testing
08/11/2011 8:00 PM
No chance of a quick post production destructive sample per batch?
When you can do destructive testing, it usually gives the most information, you can take a slice, and examine it thoroughly for defects.
08/12/2011 7:18 AM
Are you in control and capable? Can you go to an audit? Otherwise, sectioning or ultrasonic are the only options I can think of.
08/12/2011 8:28 AM
I should have mentioned that due to the nature of the production proocess and the requirements of our customer 100% product testing is required.
08/12/2011 10:02 AM
I think Archimedes solved this problem some time back. Since it is round, the mass calculation should be trivial.
08/12/2011 10:14 AM
I'd be surprised in FRP if their diameter is consistant enough to measure it by mass - especially if you're inspecting for delaminations and not just porosity.
08/12/2011 11:15 AM
08/12/2011 5:51 PM
If it is internal microvoids and delaminations, then ultrasound is the only option I know of. Backscatter X-ray might be possible, but I don't know about how small a void it would pick up.
Composites are notoriously hard to test.
Register to Reply 7 comments
jgjengr (2); newstart2k (1); NKT (2); Randall (1); RVZ717 (1)
