Previous in Forum: Overclocking a Spy Pen   Next in Forum: HT Panel Issue
Siemens SM 332 Analog Output
08/13/2011 9:18 PM
Hello,me again!
Just a simple question about a Siemens module showing a fault (red LED). Before to go any farther i would like to know if the new card # 6ES7 332-7ND02-0AB0 is an improved replacement for the original card # 6ES7 332-7ND00-0AB0 which is maybe ten years old?
Just for fun!
Pathfinder Tags: Siemens S7
Good Answers: 804
Re: Siemens SM 332 Analog Output
08/13/2011 11:01 PM
Yes, that last sequence is the version number and indicates a newer version. But you need to check with Siemens if your CPU and /or remote interface is compatible, there may have been a firmware change as well.
08/14/2011 12:27 AM
Hello, you again...
Thank you very much for answering my question, but guess what? I have another one, it is about firmware...You mean contacting Siemens, that sound laborious. OK i will try that.
PS, Iwill come back on the welding machine later.
Thank you
Just for fun!
Good Answers: 59
08/14/2011 10:28 PM
You need to contact the manufacturer in any case. Later versions are not always backward compatible.
08/15/2011 10:39 PM
Hi!
We have been in contact with our equipment vendor who is fit the plc. They told us that is all been look after. So we swaped the Signal module and the fault went away.
Thank's again for you advise.
Just for fun!
Register to Reply 4 comments
JRaef (1); leveles (1); TripppleP (2)
