Previous in Forum: Sealant or Stacking   Next in Forum: Using Non Conventional Energy Sources
Converting Pressure Washer To Aquarium Cleaner
08/21/2011 8:39 AM
The bottom of my aquarium is a thin concrete plate.
As fish excretion often sink in the bottom and with high nitrate and ammonia, I think I need to clean the bottom by using vacuum cleaner principle.
Can I suck the bottom by connecting the water inlet of a high pressure cleaner, and then dispose the effluent?
Thanks
This discussion was "closed" on 08/21/2011 6:47 PM. No new comments are allowed.
Message from admins:
This thread is a duplicate: please post your comments in the original discussion found here http://cr4.globalspec.com/thread/71501/Pressure-washer-cleaning-aquarium-tank
Re: Converting Pressure Washer To Aquarium Cleaner
08/21/2011 9:25 AM
Pressure washer cleaning aquarium tank
This is not a good idea. Listen to kamarat. You won't get better answers by posting twice.
Good Answers: 114
08/21/2011 1:37 PM
How big is your aquarium? For indoor aquariums we use under-gravel filters covered in gravel and allow an ecosystem to develop. Then change a percentage of the water at regular intervals. There are chemical systems to combat the ammonia.
You could use your pressure washer, with a Bernoulli system to pull the water off the tank floor.
I don't think that is the best way though. The fecal matter breaks down so quickly that you would have to vacuum continuously.
Register to Reply 2 comments
