Previous in Forum: AHU Commission   Next in Forum: Spray Ball Nozzle
Impeller With Radial 9 Ribs
08/21/2011 1:43 PM
The second blower, after assembly, work like siren. We have not same experience with the first blower we assembled. Capacity of the blower is 250 CFM, 2.75 PSI, @ 15000 RPM. I will appreciate suggestions to eliminate the noise.
Re: Impeller with radial 9 ribs
08/21/2011 1:51 PM
If all the parts are the same, it sounds like a clearance/fit/assembly problem.
Nobody will be able to solve this for you without A LOT MORE information.
08/22/2011 10:24 AM
Thank you for suggestion. What other information you will need?
Re: Impeller With Radial 9 Ribs
08/22/2011 12:03 AM
Can you take photos of both impellers and housings and compare them.
I am told that sometimes a rough finish on the blade ends can cause them to scream, likewise any welds which have broken could be a suspect.
But since you have one that is quiet and one that screams you have the perfect scenario to do an A/B comparison - your problem lies in the differences.
If you can swap the impellers between housings easily that also will give you a quick indication if it is the housing or the impeller....
Good luck
08/22/2011 10:27 AM
Thank you. I will try.
Jaromir Friedrich (2); lyn (1); WAWAUS (1)
