Previous in Forum: Pipe Line Warm-up Procedure   Next in Forum: Efficiency Calculation - Flue Gas Analysis
8 comments
Water Hammer - Software Called AFT Impulse
08/23/2011 1:02 AM
Hi,
Anybody using the software called AFT Impulse for analyzing water hammer (or Surge or impulse). I've some doubts related to the terms used in that software. Please let me know if you are using that.
Thank you
Re: Water Hammer - Software Called AFT Impulse
08/23/2011 10:33 PM
Hi Raj,
No I haven't used the software, but I would like to review it. Is there a tiral version available? Once I've had a look at it, more than willing to discuss the temrs used.
Kind Regards,
Anthony
Good Answers: 119
08/23/2011 11:05 PM
I was curious enough to search for it.
It's Here
Looks pretty interesting, except for the price. But there is a downloadable demo.
Hooker
Good Answers: 59
08/23/2011 10:53 PM
Water hammer vs. software.
Have you not left out a few items, as sensor, location of it, data collection as a necessary, and reading altering component? Software would be my least concern, unless I am a student too.
08/23/2011 11:42 PM
disagree - accurate software would be a godsend.
It is much better to design into the system, preventions rather than trying to cure problems after the lines have been fabricated, and pumps, valves etc have been commissioned.
Currently using formulas in excel and rules of thumb to manage this problem. A concise accurate system analysis would be excellent tool to aid in the design and commsissioning of a plant.
Trying to get my IT person to allow the download and install the Demo on the system.
Cheers,
Anthony
Good Answers: 59
08/23/2011 11:57 PM
I find the mindset, er, "interesting", to say the least. The water hammer problem is real, mechanical, hydraulical. Its source and its solution is no mystery at all.
Please explain - beyond your limited understanding, that is - what the heck you need any software for?!?
08/24/2011 5:31 PM
For one thing, when you have twenty or thirty systems (any of which can be the source), having some form of feedback to at least be able to single out the system which is hammering would be a godsend. To give an example, we have two large power plants with multiple lines which can hammer. One unit was off on outage (taken off earlier in the day) and the other unit was at full load. We heard and felt the hammer and the foreman thought the problem was related to the ties between both units caused from the down unit. When looking for a water hammer, you at times may have to listen for several hammers before determining the general direction of the hammer. I eventually found the hammer on the ground floor of the unit which was on. I had no idea which direction to go until I heard several water hammers. It turns out that a pneumatic (air supply) line had vibrated off of a regulator valve which was a default open butterfly valve. The air line was building up enough pressure to close the butterfly valve and when the pressure got up to a high enough amount, it would pop off of the connector and default open the valve and hammer the line as soon as the valve slammed open. As the pressure bled off, the connector would relax and reconnect loosely to the air fitting and start another cycle of hammering by closing the valve abruptly and then abruptly slam the valve to the open position. It was not a steam line, but a cooling water line. The only way it was found was by having men search to find the pipes that were hammering and then determine the cause. Before the cause was determined, there was at least one tear in the system piping which was patched, but will still need to be fixed permanently during an outage. Had there been software and sensory feedback equipment installed in the systems, operations could have been sent to respond to the problem in a more timely fashion. If finding the source to a questionable water hammer quickly helps you avoid further damage to your systems and avoid having an outage or extended outage to repair the water hammer damage, this type of software can pay for itself rather quickly (provided it works). This is just my opinion of course.
Good Answers: 19
08/24/2011 1:07 PM
I had the opportunity to use the software about 5 years ago for an airport jet fuel distribution system. We did have some difficulty with setting up the model but we did reproduce some of the hammer issues that airport personnel observed. System was fairly complex, 8 50-75 HP pumps, about 8000 feet of mains, and 40 or 50 aircraft fueling points.
09/02/2011 5:51 AM
I have used AFT Impulse Software (Version 4.0) recently for Water hammer analysis for CW System of an Indian project. It is quite good and user friendly. Please let me know in case someone has any query.
Register to Reply 8 comments
ajwinemaker (2); bhatta_anirbanin (1); Hooker (1); leveles (2); RG2 (1); Ried (1)
