Previous in Forum: Cadence Tool   Next in Forum: Multimeter and AM Question
Current & Voltage Operating Semiconductor Device
08/23/2011 3:31 PM
how can i know that whether the semiconductor device is current operating or voltage operating?
Re: Current & Voltage Operating Semiconductor Device
08/23/2011 4:32 PM
Read your textbook.
You always could read the manufacturer's data sheet, too.
As a final resort, you can change the current without changing the voltage or change the voltage without changing current and observe.
Good Answers: 59
08/23/2011 11:12 PM
You DO NOT. A device has characteristics, defined by physics. There is no choice for you. Now, you decide, how to USE a device.
Example: a power Mosfet can be used as a parallel resistor, a series resistor, a good switch, a poor capacitor. What do you want? More exactly, what can be extracted from it in a given configuration? It is not a simple question.
08/24/2011 2:41 PM
i know sir this is not a simple question but i want to know the basic thing that how can i detect that the device is current operating/voltage operating.
08/24/2011 3:11 PM
You don't seem to be willing to do your own research here, do you. I say this because without a good understanding of fundamental circuit theory it is very difficult to give you an accurate answer.
You see a single simple BJT (2N2222A) is typically considered a current sensitive device but with the inclusion of just one resistor the whole circuit can be made into something resembling a voltage sensitive device. A collection of BJT and resistors can make what is known as an operational amplifier (μA741) that operates like an ideal voltage sensitive device.
Similarly a FET (2N4416A) nominally operates as a voltage sensitive device but again just one strategically placed resistor can make the whole circuit to approximate a current sensitive device.
Good Answers: 42
08/24/2011 1:25 AM
Look up the part number.
08/24/2011 11:20 AM
A very general answer to your question is that a Bipolar Junction Transistor (BJT) is controlled with current, and a Field Effect Transistor (FET) is controlled with voltage.
08/24/2011 2:38 PM
sir please tell me how can we know that the FET is tg. deice whether the BJT is current operating device. please explain with example.
Register to Reply 7 comments
GW (1); leveles (1); redfred (2); sahil123 (2); WoodwardDL (1)
