Previous in Forum: Induction Motor   Next in Forum: 2 SPDT Relays to Control Operating Pressure Range
Need a Circuit to Boost TV Antenna Volt to 5Volt
08/26/2011 7:45 AM
i need an electronics circuit to boost my television antenna from its micro volt from the air directly to 5 volt before plugging to the television.
Re: need a circuit to boost tv antenna volt to 5volt
08/26/2011 7:52 AM
Well, perhaps your local authorities should issue a court order that you should not be alowed to get closer than 20ft from your antenna, and 5ft from your TV. You can always use the remote. S.M.
Re: Need a Circuit to Boost TV Antenna Volt to 5Volt
08/26/2011 8:08 AM
It's not 5 volts, but here's one.
Good Answers: 44
08/26/2011 10:32 AM
Why so high? What purpose are you trying to serve?
Register to Reply 3 comments
Anonymous Poster (1); cuba_pete (1); kramarat (1)
