Previous in Forum: Friction Load   Next in Forum: DC Motor Control Issue
Grounding
08/26/2011 1:35 PM
hi guys
for 300 Amp system what type, diameter and number required for grounding rod (according to CSA code)or NEC.is there any useful table may used in future?
i will appreciate any comment........thank you
Good Answers: 58
Re: Grounding
08/26/2011 2:05 PM
Is this for service entrance or equipment load?
Here is a ground conductor calculator link:
Link
You can reference:
NEC - Table 250-66 and NEC - Table 250-122
Here is another great calculator
Re: Grounding
08/28/2011 3:24 AM
thanks and any thing about rod?
Re: Grounding
08/28/2011 9:25 PM
thanx
Good Answers: 140
Re: Grounding
08/26/2011 2:20 PM
With your last question... I took the time and the bother to write up a full detailed response, that you never bothered to take the time to respond to.
So... this time, here is my response to this question.
Look at... CSA C22.2 No. 41.
Re: Grounding
08/28/2011 3:22 AM
Well,i have a bad feeling write now ,and would say thank you ,but i want you to know that i was so busy last couple weeks as i had just few hours for sleeping and that's it, and didn't want to be miscreant with you cause you deserve an appreciation ,so.....thank you
Re: Grounding
08/26/2011 6:12 PM
Table 250.122 Minimum Size Equipment Grounding
Conductors for Grounding Raceway and Equipment
Rating or Setting of
Automatic Overcurrent
Device in Circuit Ahead of
Equipment, Conduit, etc.,
Not Exceeding (Amperes)
Size (AWG or kcmil)
Copper Aluminum or
Copper-Clad
Aluminum*
15 14 12
20 12 10
60 10 8
100 8 6
200 6 4
300 4 2
400 3 1
500 2 1/0
600 1 2/0
800 1/0 3/0
1000 2/0 4/0
1200 3/0 250
1600 4/0 350
2000 250 400
2500 350 600
3000 400 600
4000 500 750
5000 700 1200
6000 800 1200
Register to Reply 6 comments
KJK/USA (1); MegaThink (3); North of 60 (1); wareagle (1)
