Previous in Forum: Bisphenol A Epoxy Resin   Next in Forum: The Rise of Slime
Liquid Poly Material for Medium Manufacturing Plant
04/20/2007 9:27 AM
Dear sirs,
At the moment now we are at the competitive level on world market on magnet wire production, so we are trying to look for maker of polymer base material (Polyester,Polyimide,Polyurethane) for our product at our factory. At the moment now we are facing difficulties in searching for manufacturers of these type of material,so i would like to know whether anyone who is linked to this forum has any information on chemical manufactures (in your state or country) or new material being created (exp.Dupont) or any other material manufacture's involved in this kind of product.
Thank you
Pat J
Re: Liquid Poly Material for Medium Manufacturing Plant
04/21/2007 8:34 AM
You might want to try HumiSeal for polyurethane.
I've had good luck with it in our plant.
Russ
Russ
04/27/2007 6:59 AM
Thanks guys i will try to go through the addresses,and also you mention that you are from HumiSeal and what are you guys manufacturing there? Can i have the address, if so the material i am looking for is what you guys are doing and is it for sale outside US and the export/import regulation.
Thank's
Pat J
04/21/2007 10:10 PM
Most magnetic wire has historically been coated with a polyurethane - phenol "TPU" that was dissolved in a cresylic acid solution. GE used millions of pounds, coating wire at very high speeds. The PU coating melted under the heat of a soldering iron, and was an ideal insulator in motor windings. For sources of this and similar coatings, look up the PMA (Polyurethane Manufacturing Assoc) on Google, etc. They will direct you to suppliers. Good luck!
04/27/2007 7:05 AM
Thanks guys,hope to go through the addresses as soon as possible and hope to hear from you soon.
Pat J
05/08/2007 2:57 AM
Send the resin specifications (for polyester, epoxy or polyurthane) at a given specified temperature. I can supply tonnes to you, being a plastic technologist myself and having access to all such resin manufacturer, other than Dupont.
I am in India
Thanks
Chan
05/08/2007 8:43 AM
Thanks Chan,at the moment now we have some manufactures from China and Germany with us (quotes) so why not, i will try to send some information to you as soon as possible.
Thank You
Pat J
Register to Reply 6 comments
Anonymous Poster (4); Cardio-2 (1); Russ (1)
