Is there anyone out there who knows of a supplier of a carbon tipped clamping tool which can be connected to an extra low voltage [e.g. say 5 volts] high current source which when the current flows though the carbon tips heats up the work [or joint] clamped between the carbon tips. When sufficiently hot, silver solder can be introduced to the joint to create a welded connection?
Greg lynch
