Previous in Forum: Fibre Index in Milling Section in Sugar Mill Definition and Formula   Next in Forum: What Is the Equation that Governs the Pressure Wave Form of Trapezoidal Type?
What Is the Flow Work for Isothermal Process?
09/02/2011 1:32 AM
As we know that for a isothermal process PV=Constant and PV is equal to flow work...so what is the rate of flow work for isothermal? is it zero? Am I correct? if not correct me.
Paresh B. Gujarati
Re: What Is the Flow Work for Isothermal Process?
09/02/2011 7:20 AM
Yes the work done by the system will be zero
Good Answers: 137
09/02/2011 12:16 PM
No, it's not zero and you're not correct!
In polytropic compression non-flow work = 1/(r-1)*P1*V1*([P2/P1]**[(r-1)/r] - 1).
Flow work is r*non-flow work. Then putting (r - 1)/r = n, flow work = 1/n*P1*V1*([P2/P1]**n - 1). For adiabatic compression r = γ = 1.41. For practical compressor duties r usually taken as 1.3, giving n = 0.3.
In isothermal compression r = 1, n = 0, and non-flow work and flow work are the same, and = P1*V1*ln[P2/P1].
You can show using de l'Hopital's theorem that the limit of 1/n*P1*V1*([P2/P1]**n - 1) as n → 0 is P1*V1*ln[P2/P1].
Codey
Good Answers: 137
09/03/2011 8:03 AM
Perhaps I should have added that to calculate power (implied by your ....rate of flow work for isothermal) the V1 in the equations is flow, not volume.
Codey
Good Answers: 183
09/03/2011 6:40 AM
You can put it also in an other way. Temperature is constant if the output and input of energy are equal. For instance if you heat an expanding gas you make a work and at same time heat it temperature stays constant. If you compress a gas and cool it the effect is the same.
Good Answers: 137
09/03/2011 8:03 AM
Well, yes, but what has that to do with the OP's question?
Codey
Codemaster (3); nick name (1); shujabutt (1)
