Previous in Forum: Cable Storage   Next in Forum: Transformer Selection
Motor starters Power ranges
09/08/2011 6:43 AM
Hi,
I just need to get the statement in NFPA where they specify the motors starters types according to their nominal power. (Example: Direct Online from 1 to 10 HP, etc.). I have the NFPA collection but can't find it.
Thank you in advance.
Good Answers: 181
Re: Motor starters Power ranges
09/08/2011 8:56 AM
I'm not surprised it doesn't give ratings. DOL can go in to 1000's of HP if the supply is robust.
Good Answers: 804
09/08/2011 9:44 AM
There is no statement like that in the NEC (NFPA electrical code), they don't care. The need for reduced voltage starting varies by utility and even neighborhood. There is no national standard.
Good Answers: 244
09/08/2011 6:53 PM
I think you are talking about NEMA starter size. It is not defined in NFPA. It is called in NEMA motor starter size. See this link: http://www.communitymotorsinc.net/nema_starters.htm
- MS
JRaef (1); msamad (1); TonyS (1)
