Previous in Forum: Ways to Mitigate Pressure Build in Confined Chamber Due to Thermal Expansion   Next in Forum: Material Specifications
9 comments
Electrostatic Precipitator
09/12/2011 2:03 AM
How much market potential is their For Dry & wet ESP (Electrostatic Precipitator )In India?
In which industry WET ESP Used?
In which industry Dry ESP Used ?
Is WET USP used in thermal Power Plants?
Suppliers & Manufacturers of Dry & Wet ESP.
Indian Market For ESP?
Good Answers: 125
Re: Electrostatic Precipitator
09/12/2011 1:17 PM
When I was in the US Navy, all ships had electrostatic precipitators installed in every electronics space to eliminate airborne dust. They did a good job at that but the popping noise was annoying.
Good Answers: 101
09/12/2011 9:37 PM
Plenty. Real question is how many potential clients are willing to pay for them since they're not cheap.
Anywhere flammable dust is produced e.g. grain dust.
Anywhere non-flammable dust is produced e.g. cement.
Can be used
Do a Google search.
See Q1 above.
09/13/2011 12:47 AM
What are the recommended voltages and gap between +ve and -ve electrodes for each application? What kind of electrodes(plate,wire etc) are recommended?.
pnaban
Good Answers: 101
09/14/2011 12:57 PM
High voltage low current . Average 20,000 volts.
+ve: plate.
-ve: wire.
09/14/2011 10:41 PM
Thanks. Is there a table of materials(wire/plate) for each application(grain/cement etc)?.
pnaban
Good Answers: 101
09/15/2011 10:45 AM
Best advice I can give you on this is to check with a supplier what is best for your required application.
09/30/2011 1:45 AM
Thanks for your fruitful responce.
06/23/2012 11:53 PM
dear friends,
I THINK THAT YOU HAVE MISTAKEN IN READING THE QUESTION,
It is DRI (DIRECT REDUCED IRON) i.e., ESP of DRI plant.
DRI PLANT is a plant where OXYGEN is being removed from the HEMATITE
Type IRON ORE,having chemical reaction with COAL.
NOW you reply the "Q", and if still having some doubt can cleared it by asking it in REPLY.
Waiting for the reply/discussion.
Register to Reply 9 comments
Anonymous Poster (1); DVader1000 (3); pnaban (2); ratnakar (1); sanjay1971 (1); WJMFIRE (1)
