Previous in Forum: Winding Factor   Next in Forum: Greeting for Engineer`s day
8 Pin Relay Wiring
09/14/2011 7:06 PM
How do you wire a 250 volt 30 amp 8 pin relay for a water heater? The relay has the #'s 1,2,3,4,5,6,7,8 ej: 1------2 3------4 5------6 7------8
Re: wiring a 8 pin relay
09/14/2011 7:14 PM
Knowing how to wire a relay requires knowing more than just the first eight integer series numbers. You also have to know critical simple things like your local power wiring standards, how to turn OFF the power to the heater and what the control voltage for the relay will be. I recommend that you contact an electrician before you burn your house down or electrocute somebody.
09/14/2011 7:19 PM
First, locate the wiring diagram that should be somewhere on the unit.
Then you can point it out to the service tech that you should call to do this job.
Re: 8 Pin Relay Wiring
09/14/2011 10:48 PM
This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
-CR4 Admin
09/14/2011 11:41 PM
What does this have to do with the price of rice in China of a summer's eve?
Register to Reply 4 comments
ledmodulelight (1); lyn (1); redfred (2)
