Previous in Forum: Diesel Common Rail: Polluted Fuel Oil Damage   Next in Forum: 1998 Cavalier - Won't Start, Please Help
Having Trouble With 99 Cavalier, Can Someone Please Help
09/27/2011 8:57 PM
i have a 99 chevy cavalier,2.2 engine, we changed the head an engine started a couple times an then wouldnt start anymore, it turns over find, but no fire to plugs, we changes the cam an crank senors,an found out no power on the ign module, what can be the cause of that?
Re: having trouble with 99 cavalier, can someone please help
09/27/2011 9:02 PM
The fact that you have worked on this already, mostly removes any hope of help for you.
Take it to the shop.
Good Answers: 70
09/28/2011 12:37 AM
Looks like LynDoor™Industries, got their advertising all worked out as we have another Chevy Cavalier question and little information.
Good Answers: 58
Re: Having Trouble With 99 Cavalier, Can Someone Please Help
09/28/2011 8:25 AM
If you have no power to the ignition module, it would make sense to check the wiring/breaker/fuse to the ignition module.
Good Answers: 101
09/28/2011 12:55 PM
Best option would be to melt the car down to it's base minerals and sell the weight as scrap metal.
Good Answers: 123
09/28/2011 1:05 PM
I have managed to eat every day by repairing other people's vehicles. There are a few absolute rules to live by in the repair business.
1) The last person that touched it screwed it up.
2) What has changed since it last ran correctly.
3) If it ain't broke don't fix it.
If you are sure it has no electric spark, check all of the electrical connections you disturbed.
Why did you take it apart in the first place? Was it cutting out? Stalling and then not restarting? Did you rebuild the motor because it had a bad ignition switch?
Get a wiring diagram, and follow the start and run circuits. The coil pack or distributer should be live in start and run. Good luck.
Bob
Good Answers: 70
09/28/2011 11:30 PM
Do you have a repair manual for your car? If you don't, invest $20.00(us) and buy one. Without one your lost from the get-go. Most decent manuals will have troubleshooting flow charts. You will need some basic tools to do the troubleshooting, like a test light, volt/ohm meter for electrical. As other's have said, it could be a blown fuse or fuses, Most ECM's are power by 2 or more fuses. Other than that, you may need to replace the ECM. Maybe you and ullyceese can get together and trade parts and figure out what's broken between the two of you
09/29/2011 11:55 AM
How is the ignition module grounded. Does it use the head as the ground point. Is the head properly grounded to the engine block. Was there some sort of metal strap you forgot to put back on. I assume you have a multimeter. Check the basic stuff.
Register to Reply 7 comments
bob c (1); dj95401 (2); hatchera (1); KJK/USA (1); lyn (1); RVZ717 (1)
