Previous in Forum: Burner Piping Elevation   Next in Forum: Material Used for Internal Circlips?
Non ferrous material-ASME GRADE
09/28/2011 10:12 AM
We are using the following non ferrous materials for flare tip and associated piping for refinery application:
Incoloy 825 for hydrocarbon flare tip and associated piping
Inconel 625 for Acid flare tip and associated piping
Questions:
1-Pls inform the chemical composition of the two materials above.
2-Kindly inform the equivalent ASME Grade for plates, pipe, forging (flange), fittings etc.
3-Any special inspection/testing/NDT requirements to be followed for these materials
EIL
This discussion was "closed" on 09/28/2011 10:39 AM. No new comments are allowed.
Message from admins:
Duplicate. Please See: http://cr4.globalspec.com/thread/72525/Non-ferrous-material-ASME-GRADE
Re: Non ferrous material-ASME GRADE
09/28/2011 10:22 AM
If we do all the work for you, what will you do?
