The standard practice on large electric motors is to insulate bearing at one end which is normally NDE.Is it necessary to insulate bearings at bot ends?I have read long back that insulating both ends can result in a large static build up as no discharge path exist.( So you have to provide a shaft grounding brush)is it really necessary to insulate both ends?
