Previous in Forum: Re: Roof & Compression area Design For high internal pressure 17.5 -18 Kpa   Next in Forum: Pressure Drop in Condenser
Good Answers: 56
Operating Temperature Ranges For Disk Brake Calipers
09/30/2011 7:54 PM
Can anyone here give me an idea of how hot the calipers get on the front disk brakes of an average weight car under normal use?
By average weight I'm thinking in the range of about 2800 pounds (1250 kilos).
Thanks
Laughing Jaguar
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Re: Operating temperature ranges for disk brake calipers
09/30/2011 8:02 PM
It is like asking how much weight of a normal size barrel of water , filled to normal level will weight .
My friend, how hot it gets depends on how hard you brake, at what speed and how often !
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
09/30/2011 8:38 PM
More than you'll ever want to know:[PDF]
EXPERIMENTAL STUDY OF AUTOMOTIVE BRAKE SYSTEM ...
Good Answers: 80
10/02/2011 10:28 AM
GA! very interesting paper. Thank you.
Good Answers: 56
10/02/2011 12:52 PM
I'm not sure why a simple question about average temps for an average car under average conditions should have proven so problematic. Fortunately Lyn provided a link which ball parks the answer so I can apply thermal coatings with a range of heat tolerance to satisfy our needs.
Thanks Lyn
Laughing Jaguar
09/30/2011 9:06 PM
Hello
Google & Wikipedia ,the world is on your screen.
glenesterline@gmail.com
Good Answers: 114
Re: Operating Temperature Ranges For Disk Brake Calipers
10/02/2011 8:41 AM
I'll hijack & ask
why isn't there a rating for the braking power available?
things like diameter, the number of piston per caliper, pad material all factor in...
the natural choice would be Brake Horsepower
the temperature rating would be the number of times per minute the maximum force could be applied, without boiling the fluid...
Register to Reply 6 comments
bravo88 (1); g66 (1); Garthh (1); Laughing Jaguar (1); lyn (1); marcot (1)
