Previous in Forum: Solar LED Lighting for an Art Gallery   Next in Forum: Electrical Design Software
12 comments
Bus Bar Support
10/09/2011 7:10 AM
Can we use Wood as busbar support for 1750 Volt DC, if not please explain me.
Thanks for same.
Re: Bus Bar Support
10/09/2011 7:51 AM
I would imagine it would be classed as a fire risk so I doubt it would be allowed! Check out you local standards to be sure!
Re: Bus Bar Support
10/09/2011 7:59 AM
i would'nt think any flamable material would be a good choice.
Re: Bus Bar Support
10/09/2011 8:29 AM
Carry out insulation resistance test on that piece of wood possibility is that the requisite insulation value is not being met.
If you must use wood as support material, impregnate dry piece of wood in electrical grade varnish for 24 hours and re-test for insulation resistance when dry.
Flammable material like; paper, cloth tape and wood are extensively used in areas like motor winding or transformer coil winding.
Codes like IEC provides Y, A, E, B, F, H,C, classification for materials, you need to study a book on electrical insulating materials.
Good Answers: 804
Re: Bus Bar Support
10/09/2011 10:27 AM
Flammable materials like paper used in electrical equipment is NOT used as an insulation material however. And it has been rendered non flammable as well.
Re: Bus Bar Support
10/09/2011 10:50 PM
In cables made long back impregnated paper was used as an insulator but covered so that it won't come into contact with water/rain/moisture.
pnaban
Re: Bus Bar Support
10/10/2011 12:09 AM
Knowledge sharing is a WIN-WIN situation
Good Answers: 181
Re: Bus Bar Support
10/09/2011 9:20 AM
In some parts of the world wooden pin insulators have been used on OH lines.
That aside, I wouldn't recommend it.
Re: Bus Bar Support
10/09/2011 10:40 AM
No. If it catches on fire, your bus bar may short out.
Re: Bus Bar Support
10/09/2011 1:21 PM
No it's not allowed at any where in the world and none of any utility standards in the world defines the wooden busbas supports.It gets wetted, can absorb moisture and can catch the fire in case of short circuit.So stay away from this idea.
There are no shortcuts on the road to a great experience.
Good Answers: 804
Re: Bus Bar Support
10/09/2011 4:28 PM
Well, to be fair, if ANYTHING gets wet inside of a bus bar compartment, the wet wood will end up being a minor side issue to the overall catastrophe...
Re: Bus Bar Support
10/10/2011 12:52 AM
Generally said, regardless either busbar is fitted inside any compartment with IP protection or not. :)
Re: Bus Bar Support
10/10/2011 1:31 AM
Wood falls in Y-classification, please go through the following link;
http://jinlong.onsugar.com/Classification-performance-insulating-materials-15679160
Register to Reply 12 comments
A.A.Khi (1); Anonymous Poster (1); Aseer (2); JRaef (2); lyn (1); mountk2 (2); Mr. Truman Brain (1); pnaban (1); TonyS (1)
