Need help,
We use a small DC electric base motor that runs a gearbox to get the torque output we need to operate our valves. Of late we are getting a few failures where when we disassemble for evaluation we find a black fluid like substance in the amature and commutator area as well as down the sides of the inside of the base motor. The gearbox contains a light colored synthetic grease that the vendor claims will not vaporize below 250°, the gearbox is not sealed against wicking. The actuator itself is a sealed unit so that outside contamination is not likely.
If the base motor experiences a near stall condition, the PCBA will protect against over amperages of more than 5 amps the motor operates at less than 1 amp under normal conditions.
If the base motor is operated in such a way as to be overamped and creating heat can the brushes begin to break down could this create a small amount of a fluid like substance in such a way as to create a short in the commutator and armature?
