Previous in Forum: Weight calculation   Next in Forum: Balance 16 Small Hyd Cylinders
gd square value of vacuum pump rotor
10/11/2011 11:29 AM
Dear members,
I have raised this question long back. Although I have a detailed drawing I could not
send the same to respective member. Please if the e mail I.d.is given I shall forward
the reference drawing.
Regards
P.M.M.KRISHNA MURTHY.
Email Removed- Cr4 Admin
Good Answers: 67
Re: gd square value of vacuum pump rotor
10/11/2011 12:13 PM
I could not see any question here.
10/13/2011 8:23 AM
Gentlemen,
In fact we are in the line of vacuum pump manufacturing. Customers often ask for
gd square value of rotating part. I want to send one drawing of the component for
which I request you to guide me calculate gd square value. I am little bit confused
to send the drawing through this mail. Please give me your email I.d. so that I can
send you the respective drawing.
regards
Good Answers: 67
10/15/2011 1:33 AM
If you are a manufacturer of vacuum pumps and not aware about how to calculate GD2 value of its rotors, then I can't help you, God only can help (refer hand books).
10/17/2011 6:55 AM
Gentleman,
Please indicate your email I.D. so that I can send the related drawing for which I need
to calculate gd^square value. Some there is a confusion for me to send the drawing
through cr4 forum. Hope you will understand and help.
Regards
Register to Reply 4 comments
