Previous in Forum: Cracking of Steam Coils of SS316L of Sulphur Pit   Next in Forum: Polar Mohr Eltromat 90CE Operators Manual
Difference Between Cold Forging & Hot Forging?
10/13/2011 5:29 AM
What is the difference between cold forging & hot forging? which one is suitable for EN19 material?
Re: Difference between cold forging & hot forging
10/13/2011 7:14 AM
Not sure about EN19, but hot forging uses metal at a more plastic state due to temperature. Through cooling the metal's properties can be set to make it harder and brittle or softer but stronger.
Cold forging uses powerful hammers or presses to form metal while cold. This method induces stresses within the metal that can cause cracks later, but is usually less expensive to manufacture. Sometimes those stresses are desired in the final product.
Drew K
10/13/2011 8:06 AM
Thanks.
Sir, actually i have to manufacture M20X50 (grade 8.8 i.e. hardness 22 to 32 HRC, tensile strength 860 N/mm2 min.) screw from EN19 material so which process should i use cold forging or hot forging.
Good Answers: 146
10/13/2011 12:16 PM
incus opella
10/14/2011 8:30 PM
Kindly inform us where these screws will be sold.
Good Answers: 146
10/14/2011 8:53 PM
Damn. That is the best answer...!
incus opella
10/14/2011 9:51 PM
Register to Reply 6 comments
artsmith (2); Drew K (1); lyn (2); vishal1987 (1)
