Dear Learned friends,
I am trying to start a 4500kW 13.8kV motor Direct Online. The motor is connected at 13.8kV Switchgear bus which is supplied by a 69/13.8kV 40MVA transformer. The 13.8kV switchgear feeds 12MVA 13.8kV loads and other 4.16, 0.48 loads at the down stream totalling 25MVA loads. I want to maintain max 10% voltage drop at 4.16kV & 0.48kV buses during DOL starting of the motor. Will the motor be started DOL with the voltage dorp limit criteria. In case no, will adding capacitor at motor terminal during starting will help to maintaining voltage drop. Also will the %age impedance change at 40MVA transformer will also help. I have tried with ETAP static & Dynamic model. But the voltage at 4.16 & 0.48kV downstream swgr is coming below 90%.
