Dear all,
during inspection of some hydraulic hoses prior to flushing, I have found a big amount of rust inside the same. I opened the original plastic bag and the plastic lid of the same, so no external dirt out of manufacturing or corrosion is there.
With a pipe, I do not have a problem. A reputed company was hired to do a proper pickling prior to flushing and, seeing the hoses, they were keen to proceed in the same manner. As per their info, the connectors at the end of the hose will loss a maximum of 0,15mm in thickness, and the zinc treatment they have. After that, they propose to treat the metal surface by phosphating it.
The treatment proposed it is said to be: degreasing, washing,"soft acid wash", neutralising, washing, drying, surface treatment, oil flushing and packaging.
Hoses data: ID50mm , PN300bar (operating pressure 90-110bar), L 2800mm, 64 units.
Neither cheap nor fast to deliver here at site.
The doubs I have are:
In wich way can affect to the rubber hoses, and ther reliability?
Does anyone have experience with a situation like this?
Could do better a manual cleaning of the metal connectors and, then, proceed with the flushing?
I am getting a measuring tool to check wall thicness, and waiting answer from manufacturer as well.
Of course they would be replaced if required, but not without a good reason, or having checked all viable possibilities.
Here some pics too, and Many thanks for your input.
