Previous in Forum: AC Welders   Next in Forum: Force Needed to Roll a Block of Titanium
Valve Clearance
10/16/2011 7:18 PM
Good day sir!
I'm just a beginner working on an motorcycle engine i would like to ask what is the most common measurement or clearance that you usually use in adjusting intake and exhaust valve of a motorcycle engine? thank you god bless!
Good Answers: 70
Re: valve clearance.
10/16/2011 7:27 PM
I would highly recommend getting a repair manual for your particular motorcycle. And without knowing the make, model and year, any one's guess would be as good as any other. If your valves are not set to specs, you run the chance of the valves staying open and burning or not opening enough and either not starting or running poorly
Re: Valve Clearance
10/16/2011 8:55 PM
dj95401 is right. You could also bend the valve stems if you don't get it right.
Look up the specs for your particular engine on the web.
Good Answers: 141
Re: Valve Clearance
10/16/2011 11:09 PM
Meanwhile you can start with 2 cycle engines - without valves?
Plenty of room here
Register to Reply 3 comments
dj95401 (1); dvmdsc (1); lyn (1)
