Previous in Forum: For 11kV Cable Sizing   Next in Forum: Circuits of AVR, For a Three Phase Generator
Neutral Disconnect Switch
10/28/2011 7:22 PM
Hi,
If a gen set is synchronized parallel with utility and its neutral switch fail to disconnect, what are the possible risk to the generator and the one who is operating it ?
Good Answers: 58
Re: NEUTRAL DISCONNECT SWITCH
10/28/2011 7:35 PM
I'll go out on a limb here and say no real risk to anything. Where the gen connects to the utility the neutral should be connected to ground, so I can't imagine any problem if a switch does not disconnect the gen from the utility.
mike k
Good Answers: 59
Re: Neutral Disconnect Switch
10/30/2011 12:25 AM
I will go out on the limb, and say that it will blow up into your face.
Good Answers: 244
10/30/2011 1:04 AM
It is suggested to disconnect the neutral with the line conductors. In LRG (Low Resistance Grounding) or HRG (High Resistance Grounding) system, the neutral is not at ground potential. In the case of solidly grounded system, the neutral is supposed to be at ground potential but if neutral is not properly grounded, there might be voltage in the neutral. In all cases, there is possibility of having voltage at neutral point. So, if the generator neutral is not disconnected from the utility system (the utility neutral is connected to the generator neutral point), there is a risk of the presence of voltage at generator neutral and hence a risk of hazards to the generator as well as the operating and the maintenance personnel.
These related links also may help:
http://www.kraftpower.com/pdfs/KPC_Info_05_switching_neutral.pdf
http://www.cumminspower.com/www/literature/technicalpapers/PT-6005-GroundingAC-1-en.pdf
http://www.cumminspower.com/www/literature/technicalpapers/PT-6006-GroundingAC-2-en.pdf
- MS
Register to Reply 3 comments
leveles (1); mike k (1); msamad (1)
