Previous in Forum: What Is Choked Flow? In What Conditions Choking of Flow Occurs?   Next in Forum: Chocolate Machine
Diesel Engine Torque
10/31/2011 12:33 PM
i have diesel engine, kubota Z-482, maximum torque at 2400 to 2600 Rpm
i will use it at 1400 to 1500 Rpm, because i will only use for drive 2KW core-less PMG
did i must add the mass of flywheel engine with purpose to correct engine torque at low speed ....?
and if i try to add mass of the flywheel engine let say by 1.5 to 2 times from initial mass, what will happen ....? what is the bad impact .....?
regards
www.dieselenginemotor.com/kubota/supermini/page2.html
Good Answers: 137
Re: Diesel Engine Torque
11/04/2011 1:58 PM
If the engine torque at 1400 to 1500 rpm is greater than the load torque you should have no problem.
Not sure what you're getting at with additional flywheels, but it wouldn't be easier to fit one.
