Previous in Forum: Allowable Bend in Rods   Next in Forum: Holding Force of Sleeve
How to Find Withstand Load for SSB Over Hanging Beam with Two Point Loads?
11/02/2011 4:18 AM
How to find Withstand load for Simply supported overhanging Beam with two point loads ?
Pls reply for this ..............
Good Answers: 179
Re: How to Find Withstand Load for SSB Over Hanging Beam with Two Point Loads?
11/02/2011 9:26 AM
There is insufficient information presented to effectively answer your Q.
You need to supply the beam span, the location and magnitude of the concentrated loads (respectively), the type of beam, the beam material properties as well as the sectional properties.
[Sounds to me like another homework problem, presented by yet another clueless engineering student.........if so, crack open your "Statics & Strength of Materials" textbook that your professor requires you to study and study your arse off until you know how to solve the problem correctly.....we don't help students answer their homework problems in this forum!]
How To Get CR4 To Help With My Homework?
11/02/2011 11:09 AM
Good Answers: 179
11/02/2011 1:21 PM
Ummmmm.....just couldn't help myself!!!!!!! hehehehe
11/02/2011 6:28 PM
Dear kannavalla
Greeting to you
here you are solved example for rack support beam
follow the procedures
Pipe Line
:- For size 4" sch.40 (STD.)
SA-283 Gr. C equ. to ST.37
:- Rack support material
108247
15,700:-
(Ss), Max. allowable stress for support material - (Kpa, (psi))
114.3
4.5:-
(Do), Outside Diameter (mm,(in))
6.02
0.237:-
(tn), Nominal wall thickness (mm,(in))
16.07
10.79:-
(w), Weight of empty pipe (kg/m,(lb/ft))
1000
0.0361:-
(ρ), Fluid density(water) (kg/m3,(lb/in3))
5000
196.85:-
(L), pipe span between two supports (mm,(in))
1000
39.37:-
(Lm), Moment arm length for pipe acting on support (mm,(in))
9.81
32.19:-
(ACC), Acceleration (m/s2,(ft/s2))
Inside diameter of pipe
(d) =
Do-2*tn4.03in102.26mm
Internal fluid weight
(wf) =
(Π*d
2/4)*L*ρ
90.49lb41.04kg
Total weight of pipe
(wT) =
(w*L)+w
f
267.63lb121.39kg
Load acting on support due to total weight
(wL) =
w
T*(ACC)
8613.6lb.ft/s
1190.88kg.m/s
Weight of any concentrated load acting on support
(wC1) =
0.00lb0.00kg
concentrated load weight represent in weight of other pipes supported on cantilever
Moment arm length for w
c1 (LC1) =
0.00in0.00mm
Weight of any concentrated load acting on pipe
(wC2) =
0.00lb0.00kg
c2 (LC2) =
0.00in0.00mm
(wC3) =
0.00lb0.00kg
c3 (LC3) =
0.00in0.00mm
Load acting on support due to concentrated load w
C1 (FC1) =
w
C1*(ACC)
0.0lb.ft/s
0.00kg.m/s
C2 (FC2) =
w
C2*(ACC)
0.0lb.ft/s
0.00kg.m/s
C3 (FC3) =
w
C3*(ACC)
0.0lb.ft/s
0.00kg.m/s
Total load acting on support
(WTL) =
W
L+FC1+FC2+FC3
at mid (assuming)8613.6lb.ft/s
1190.88kg.m/s
Bending moment due to w
L (MwL) =
(W
L/4)*(Lm/1000)
403.7lb.ft297.72N.m
Bending moment due to F
c1 (MF1) =
(F
C1/4)*(Lc1/1000)
0.0lb.ft0.00N.m
c2 (MF2) =
(F
C2/4)*(Lc2/1000)
0.0lb.ft0.00N.m
c3 (MF3) =
(F
C3/4)*(Lc3/1000)
0.0lb.ft0.00N.m
Total bending moment acting on support
(MT) =
(M
wL)+ (MF1)+ (MF1)+ (MF1)
403.7lb.ft297.72N.m
Modulus
(Z) =
M
T/Ss
0.168in
2.750Cm
select the Rolled Steel Channel (RSC) section from structural steel beam tables
S5X10 RSC
RSC weight10.00lb/ft14.88kg/m
Modulus (Z
S) for selected RSC =
1.37in
22.450Cm
check
ZS > Z
Ok
Modulus of elasicity
(E) =
210000N/mm
30457925Ib/in
Moment of inertia
(I) =
1.22in
507802.3mm
Maximum deflection
(ς) =
(w
TL*Lm3)/(48*EI)
0.009in0.233mm
safety ratio
(SR) =
(ς) / L
m
0.0002
check
S
R < 1/360
Ok
enlightenment is blessing and self-denial is a good recipe
Register to Reply 4 comments
blackpanic73 (1); CaptMoosie (2); Doorman (1)
