Previous in Forum: Squash Court Light Replacement   Next in Forum: Wood Stove Pipe Longevity
Welding
11/03/2011 8:53 AM
Is it ok to fully weld purlins to its cleats and the top chord of a truss?
Pathfinder Tags: Welding
Good Answers: 179
Re: Welding
11/03/2011 9:58 AM
IF they both are comprised of structural steel, then why not? It's either field weld the purlins to the truss, or bolt them.....
Anonymous Poster #2
Re: Welding
11/03/2011 5:27 PM
purlins are usually made of high tensile strength steel. welding will weaken them. mild steel angle cilps should be welded to the truss then the purlins should bolt to the clips.
Re: Welding
11/05/2011 2:18 AM
Is there any in steel structural code that says it will weaken the purlins or alter its purpose?
Anonymous Poster #2
Re: Welding
11/07/2011 9:43 PM
i'm sure the manufacter would void any warrenty involved. you won't find specs because welding pulins is'nt allowed. they can only be bolted. normally one bolt near the bottom of the purlin an another near the top.
Good Answers: 21
Re: Welding
11/08/2011 12:41 PM
This is kind of an open ended question that needs a lot more info before an answer could be given. It largely depends on the type of perlin in discussion. If it is one of the old Z perlins of lighter guage materials, Factory Mutual had issues with these a few years back and required other fastening procedures and bracing. So given the fact you gave no info on what your working with, I would suggest you start with your insurance carrier. They will most likely have info that you can go on. Then you will also need to look at local building codes for your area.
Anonymous Poster (2); CaptMoosie (1); fideljr2 (1); fixitorelse (1)
