Previous in Forum: Earthquake Protection of Electrical Systems   Next in Forum: Automatic Star to Delta Converter
Tripping of Relay
11/04/2011 11:20 AM
How to overcome the nuisance tripping of relays for protection of 33KV/11KV, 7.5MVA transformer during synchronisation of 2000HP auto synchronous induction motor?
Re: Tripping of relay
11/04/2011 11:29 AM
You should first ask yourself this question. Which is the bigger nuisance, resetting a protection relay or blowing up what the relay tried to protect?
Good Answers: 181
Re: Tripping of Relay
11/04/2011 5:55 PM
What indication is the relay giving when it trips.
You should be looking for a "real" fault, not trying to mask it by changes to the relay settings. I hope the system was set up by an engineer of some repute.
11/05/2011 1:28 AM
2000HP = almost 1500KW =1.5MW which may be about 1800MVA at input (electrical)
The starting current in case yiou are DOL starter may be about 5-6 times minimum and that corresponds to the current of 9MVA (though I don't expect that you might be doing such a large motor on DOL)
Good Answers: 170
11/06/2011 9:02 AM
If you feel tripping is nuisance, why have a relay at all? Throw out the relay and... start stocking enough transformers.
Register to Reply 4 comments
Anonymous Poster (1); electricalexpert65 (1); redfred (1); TonyS (1)
