A is a 2" aluminum pipe
B is a 2-1/8" dia. x 18" collar w/ 3/4" holes alligned to holes in "A" for cotter pins.
"C" is a triangular brace of 1/2" dia. x as yet undertermined sides
"D" is a 7' x 2x2x5/16" sq. tubing aluminum
"E" are welded pad eyes where a NET will attach
What is the best method for attaching the 7' tubular post to "C"?
weld each side?
Slot the 2x2 and and then weld?
...something else?
What is the best method for giving plate "C" the strongest hold or rigidity on the collar "B" ?
A net will be suspended from pad eyes "E" and in the water. There will be several hundred pounds of bollard pull on the frame work at top speed, BUT it will NOT exceed 1000 lbs.
"A" will be mounted to a frame and cabled off to the hull of the boat. We have that already working.
I need to get a fix on how best to strengthen the triangular brace to the collar and then the tubular trailing arm to the brace.
Open for suggestions.
