Previous in Forum: Pipeline Corridors Optimization Parameters   Next in Forum: Needle Valve / Pump System
Using Stoke's Law for Determination of Terminal Velocity
11/14/2011 4:43 PM
Dear sirs,
Now I am working on the project where we are installing a line to transport a water which can contain significant quantity of sand. Main purpose is to size this line diameter small enough to have the actual fluid velocity less that terminal velocity to avoid the sedimentation of sand. Particle size is < 250 micron. Reynolds number in the piping is 90805 ....
I want to use a Stoke's Law for the determination of the terminal velocity, am I right?
Thanks in advance.
Re: Using Stoke's Law for determination of terminal velocity.
11/14/2011 5:00 PM
Re: Using Stoke's Law for Determination of Terminal Velocity
11/14/2011 11:30 PM
OP wanetd to know whether stoke's law is applicable or not. At this high Re the error margin on Stokes law would be too high.
You may like to have a look here or here
However The equations are quite more complex and there are empirical velocities available min and max for the transportation of sedimentary fluids.
Register to Reply 2 comments
