Previous in Forum: Hourmeter that Runs off Hydraulic Flow?   Next in Forum: Speedtronic Mark2
Condensation Pot
11/18/2011 11:18 AM
how condensate pot protects gauges from steam
Re: condensation pot
11/18/2011 11:30 AM
I take my answer back! See post #2.
OK, not going to take it all back, just make him work for it.
Condensate Pots
Good Answers: 299
11/18/2011 11:31 AM
Your friend PWSlack gave you a correct answer here.
Do you want a different answer, or do you need help with the answer already given?
[edit] I see your friend lyn just gave you pretty much the same correct answer.
[edit again] I see you have now added 'steam' to you question.
[edit again, again] Tag, you're it!
12/05/2011 3:40 PM
A condensate pot is used to maintain a constant level in a wet leg level measuring system. The pot is mounted above the highest level eg Steam drum and the condensate fills the wet leg to the tap of level. The excess condensate drains back into the drum. Wet leg is used to protect the DP cell (pneumatic or electronic) from the steam temperature as the condensate will cool to around ambient if mounted away from ambient heat ie the steam drum itself which will be lagged (insulated)
Register to Reply 3 comments
Doorman (1); lyn (1); Stardust (1)
