Previous in Forum: Fire Hose Nozzle   Next in Forum: Gas Turbine Generator Fuel Consumption
Heat Treatment Process
11/19/2011 10:17 PM
Can any one tell me what is the tempering temperature of h13?
Re: heat treatment process
11/20/2011 1:03 AM
11/20/2011 1:21 AM
Good Answers: 151
Re: Heat Treatment Process
11/21/2011 7:55 AM
The tempering temperature depends on what the application is. For die casting molds, the most common use for H13, 1100 deg. F is recommended which should give you Rc 45. Fore greater hardness 900 deg F will give Rc 54. In general, temper at 50 deg. F higher then the expected operating temperature of the tool. I always double temper H13 with with the second temper 50 deg lower.
Register to Reply 3 comments
