Previous in Forum: Operational Safety in Power Stations - Product Bulletin   Next in Forum: cnc milling machine level of China
India - Member -
Sealing End-shields in Generators With a Fluorosilicone Sealant
11/20/2011 1:36 AM
Gas Turbine Generator End Shield Flanges -
The application requires a sealant to be pumped in through the channel by an air dispensing equipment. Project Sales Corp introduces a sealant to address this need.
The generator rotor bearings, the hydrogen shaft seals, and oil passages supplying oils to these parts, are contained and/or supported by the outer end shields. The end shields are split on the horizontal centerline facilitating their removal. The joints between the shield halves and the joints between the shields and the stator frame are to fitted and provided with grooves for the insertion of a sealing compound, to seal the hydrogen gas in the generator casing. The application requires a sealant to be pumped in through the channel by a air dispensing equipment. This product is intended to remain in a putty-like state indefinitely, and will swell slightly when in contact with most fuels, tightening the seal in service.
The product Q4-2805 is a sealant material designed to be injected into channels to form a watertight seal. It is designed to survive harsh environments where most conventional sealants fail. It is highly resistant to contact with solvents, fuels, oils, and many industrial chemicals. Upon exposure to common fuels, this sealant will swell slightly, tightening the seal during service. Its a non-curing product and can withstand immersion in fuels and temperatures upto 200 deg C. With excellent flow charactersistics it can be injected with 223AR-6 Grover Automatic Reciprocating Fluorosilicone Sealant Gun with Cylinder for 6 - 7oz from Grover Manufacturing, USA. Q4-2805 is is effective in sealing Electric Power Generator End Shield channels on Power Generation stations requiring weather resistance and temperature extremes. It has a continuous use temperature range of -55 o C to >200 o C and is not affected by UV or other environmental factors.
Q4-2805 is designed to be injected into a flange and remains in a putty like consistency.
Q4-2805 increases the reliability in sealing the generator end shield - a critical equipment for continuous operation of the power plant. Use of the product improves reliability of equipment.
An unscheduled outage can cost a power station in thousands of dollars. Use of a reliabile proven product (also approved by GE with a Part No. for use with their Equipment) avoid unscheduled stoppages and downtime. GE Approved Part No.xxxx (available upon request)
Call Satish Agrawal on +91-98851-49412 or email sales@projectsalescorp.com to know more.
About us:
We are Importers, Marketers and India Distributors for a host of high performance gasketing brands like Marston, Birkosit, Arexons, QuikSteel, LACO, etc. used in power plant turbines/compressors and count among our customers original equipment manufacturers like Bharat Heavy Electricals Limited, Siemens, MAN Turbo, Maruti Udyog, Alstom, GKN Driveline, Renk Bearings, Kirloskar, Bombardier, Dresser Rand, and power stations including Lanco, Tata Power, Torrent, Surat Lignite, NTPCs, NPCIL, APGENCO, OPGC, Essar Power, JSW, Tata Steel Captive, Nalco CPP, GVK, GMR, SEPCO, etc.
Linkedin Page: http://www.linkedin.com/company/project-sales-corp
Facebook : http://www.facebook.com/projectsalescorp
