Previous in Forum: Gas Turbine Generator Fuel Consumption   Next in Forum: Minimum Submergence in VT pump
Know the Function of Any Pump
11/20/2011 12:07 PM
Pump is a mechanical device which converts the mechanical energy of its driving unit (electric motor, diesel engine, steam turbine, gas turbine, wind turbine, ......etc) into hydraulic energy. This hydraulic energy increases the energy of the pumped liquid and enabled it overcome the static head and the hydraulic losses in the piping system in which the pump is interposed.
The method that is used to supply the energy to the pumped liquid determines the category into which the pump is placed, so there are two types of categories where the pump can be classified: Roto-dynamic pumps and positive displacement pumps. We will discuss these types in details in the following article.
Pump is an important device that we can't neglect it in our world because......
to continue this article, you can go to my site now www.pumpseng.blogspot.com
Pathfinder Tags: function of pump
This discussion was "closed" on 11/20/2011 1:50 PM. No new comments are allowed.
Message from admins:
useless thread, op simply states the uses of pumps
Good Answers: 16
Re: Know the function of any pump
11/20/2011 12:20 PM
WTF???
I was under the impression that the CR4 community did not require internet schooling on pump theory and fundamentals?
TW
11/20/2011 12:52 PM
I suggest that you reconsider your definition of "any pump". Here are some you may not have considered.
Car tyre pump
Vacuum pumps (they come in many varieties).
Bicycle tyre pump (also many varieties, but mostly variations on this theme).
Charge pump.
11/20/2011 12:52 PM
This blog which states "For Mechanical Engineers Only" probably won't get a lot of members.
I have to agree with Tim in Mexico. There's nothing here that is enlightening.
I'm afraid I must say the same thing about: Spark Ignition Timing.
Both are nice sites for the beginner. Welcome to the forum.
Register to Reply 3 comments
JohnDG (1); lyn (1); Tim in Mexico (1)
