Previous in Forum: Marine Cables vs Land Based Ones   Next in Forum: Calculation of Tariff for Electric Power
Opera 2D
11/30/2011 4:08 AM
Hi. I dont know whether I have posted regarding this or not. Because the internet was a but slow so I had to refresh. I search for the post but it's not there so I'm gonna try posting again just in case.
I am suppose to use the software OPERA 2D to analyze the electric field distribution. my model consist of a solid insulator sandwiched between two electrodes. The upper electrode is at potential 20kV and the bottom one is grounded. The insulator has a void in the middle which is the reason for this analysis.
The solid insulator material is rubber/porcelain with relative permittivity of 5.2, but the problem is I don't know what material label to assign and which bh curve to use to define the material. Theoretically, I know how the electric field contour suppose to show, but to model it and prove it using this software is confusing.
I have searched online through forums and websites but to no avail. So, I really hope someone can help me out here.
Thank you :)
Re: Opera 2D
11/30/2011 10:03 AM
Re: Opera 2D
12/05/2011 10:36 PM
Basically, i also face the same problem with u.. Hopefully someone can help us to figure out the problem. When i put the insulating layer or insulator to become an ordinary air-gap, with the hope to get uniform field, but i failed to get the result.
P/s: The insulating layer is consists of several blocks, if the insulating layer is only consist of 1 block, i successfully to get the uniform field.
Thanks!
Re: Opera 2D
12/05/2011 10:42 PM
Hi, hope you can get help from ppl soon. Gud luck!
Register to Reply 3 comments
gemini (1); Prof. Kamaro (1); SolarEagle (1)
