Previous in Forum: Jeep Liberty High Fuel Consumption in Winter   Next in Forum: Stupid Kitty
10 comments
1998 Chevy Cavalier Won't Start
12/02/2011 8:54 AM
My 1998 Chevy cavalier quit while driving it has fuel,spark and compression,the theft light is not flashing but it still won't start.
Re: 1998 chevy cavalier won't start
12/02/2011 9:28 AM
Have you consulted the exhaustive amount of Cavalier data both here and on numerous Cavalier sites???
Odds are good that with a little work on your part you can save us all a lot of speculation.
Go forth and search.
Good Answers: 137
Re: 1998 Chevy Cavalier Won't Start
12/02/2011 11:56 AM
Does it have a toothed rubber camshaft drive belt? If so it might be broken.
Good Answers: 102
12/03/2011 3:51 AM
Perhaps the OP can describe how they determined that it has fuel,spark and compression.
Will it crank?
A theft light is an aid for nocturnal plunder right?
12/03/2011 7:03 AM
I used a grounded spark plug to determine spark. I used compression gauge it had 150 psi. I used starting fluid to see if it was fuel related. I have read several discussions onthe passlock system and tried to reset it. I have swapped parts from a running 99 cavalier (tps,map,fuel reg,ign mod and coil packs) the spark is yellow. I have cleaned the fuel soaked brand new plugs but no change. The only way the car will try to start is by holding the throttle wide open. I have shakin wiring harnesses steering wheel my head and still no luck. I am thinking a bad PCM?
Good Answers: 137
12/03/2011 9:16 AM
Spark at plugs rules out my suggestion about camshaft drive belt as the distributor is usually driven fom the camshaft.
I don't understand "used starting fluid to see if it was fuel related" - can you elaborate?
It doesn't sound like the anti-theft system as that presumably cuts the spark.
Yellow spark is slightly suspicious, a good spark is blue and "fat", so maybe that's it. In the old days that could indicate bad condenser, but with modern computerised systems I don't think there is a condenser that can be replaced readily. Maybe your swap of ign module eliminates this.
If you have fuel, spark etc all I can think of is maybe the spark timing is out, which might indicate bad PCM. Can you swap that from the running 99 cavalier?
12/07/2011 1:32 AM
a yellow spark may indicate an ignion problem. a blue spark flame is required.
12/03/2011 9:04 AM
I have heard that Del The Cat is looking for a Cavalier to give to his daughter. Offer it to him at a good price.
Good Answers: 102
12/03/2011 9:11 AM
Yellow spark is not good. May be a clue in that.
You said coil packs as in more than one. Does this have 1 coil per cylinder and no distributor?
12/19/2011 10:06 PM
Well i didn't burn it but just because u have 150 psi of compression on 4 cyl. Doesn't mean it is in time. I found it to have a broken timing chain tensioner. After a lot of head scratching and trial and error I tore it down and there it was thanks for the help,Andy.
Good Answers: 102
12/20/2011 5:03 AM
Good to hear that you nailed it. GA and thanks for the conclusion.
Register to Reply 10 comments
Andy P (2); Anonymous Poster (1); Codemaster (2); JIMRAT (1); lyn (1); Wal (3)
