Previous in Forum: Efficiency of Steam Turbine With and Without Extractions?   Next in Forum: Myford ML10 3 ¼” Bench Lathe Accuracy
11 comments
External Floating Roof Tanks
12/04/2011 2:23 AM
Dear All,
Can any one clarify that in external Floating Roof Tanks does the liquid product always touches the bottom of Roof deck or there should be a gap in between? What is the reason in both cases. It will be appreciated if reference is quoted.
History: Actually we are currently facing Mechanical seal gap problems which should be vapor & liquid tight. Liquid tight is the minimum requirement. If there is a gap between product & bottom deck of roof then why we ask Qs. for liquid tight.
Thanks in Advance.
Re: External Floating Roof Tanks
12/04/2011 2:40 AM
No gap until liquid reaches low level. Then, yes gap.
Wiki is good.
12/04/2011 4:14 AM
Dear Lyn, Thanx for the comment could you please elaborate it a bit more.
12/04/2011 8:30 AM
Good Answers: 61
12/04/2011 8:08 AM
Farhan,
You did not say what part of the world this tank is located. However even in the driest part of the world there is some chance of rain.
You do not normally want this rain to mix with your product. To take care of this problem, "Floating Roof" tanks are normally fitted with seals that prevent most of the water from entering the tank. The rain water is captured by the floating roof and drained via flexible lines inside the tank from gutters in the floating roof down to outlets near the base of the tank.
It is not perfect "no water" method but is intended to catch a very high percent of the rain water that hits the top of a tank.
Do it once and do it right
12/04/2011 10:17 PM
it is located in Oman (middleast)..thing is the is offstream and subjected to inspection there we notice seal gap of around 4 in.
Good Answers: 179
12/04/2011 10:42 AM
I do know that Anaerobic Digester tanks in wastewater treatment plants utilize a gap between the top if the liquid column and the bottom of the floating tank, so as to collect methane gas (resulting from the bacteria metabolizing the waste).
OP, are you describing an Anaerobic Digester used in a wastewater treatment plant?
12/04/2011 10:18 PM
no its a crude oil tank with 96 feet diameter having single deck pontoon external floating roof.
12/04/2011 11:23 PM
You shouldn't have any gap....fix it...
12/05/2011 1:16 AM
Sounds like your tank diameter is slightly larger at the bottom then the top. Since it is probably not feasible to modify the tank, modifying the lid is the way to go. Might try something like a flexible ring (rubber like flat material fastened at the edge of the lid) that lays flat, up the wall, then as the lid settles it flexes to take up the increasing gap toward the bottom. You should also have a valve at the bottom of the tank wall to drain accumulated water out of the tank. I worked on some tank farms some years back and they would drain the water from the bottoms of the tanks from time to time, even though they had covers. But minimizing water/dirt infiltration is always a good idea.
12/05/2011 2:09 AM
Gentlemen all the replys you made are appreciated, but still my question is in normal conditions is there any gap between Roof deck and product liquid, because as per
API 650 : APPENDIX C-EXTERNAL FLOATING ROOFS
C.3.3.5 The deck of single-deck pontoon floating roofs shall be designed to be in contact with the liquid during normal operation,
regardless of service. The design shall accommodate deflection of the deck caused by trapped vapor.
Good Answers: 102
12/05/2011 2:42 AM
No gap. That is what "in contact with the liquid" means.
You have provided your own reference.
Are you OK with that?
Register to Reply 11 comments
CaptMoosie (1); contactfarhan (4); JonathanG (1); lyn (2); PennPiper (1); SolarEagle (1); Wal (1)
