Previous in Forum: Minto Wheel Resurrected   Next in Forum: Granular Activated Carbon
Engineering Fields - Mechanical Engineering - I am here to help!!
Applications for C-Scan Ultrasonic Testing
04/30/2007 6:55 AM
what is the working principle of c-scan ultrasonic testing?
can it be used for checking the bonding % of a joint (e.g.brazed joint)?
Good Answers: 40
Re: working principle of c-scan
04/30/2007 10:39 AM
The working principle is non destructive testing using sound.
You transmit a specific known sound.
Depending on properties of the material that it is passing through, the sound will:
  • change directions, and or
  • reflect, and or
  • change speed (frequency)
When you receive the sound, either as reflected signal or with a sensor on the other side, an accurate picture that will show all the temperature and density changes of the material can be read.
See:
http://www.npl.co.uk/materials/cog/cscan.html
Yes it can be used. see
http://www.ndt.net/article/wcndt00/papers/idn201/idn201.htm
05/10/2007 6:26 AM
I am particcularly confused about interpreting the results of c-scan.
the c-scan result show the scanned image of Brazed contact. the image consists of colours which inturn indicate the so called % of bonding. but I think , bonding is proper only when there is no blow-hole in between. but the c-scan image identifies the position of the blow hole & correspondingly gives the % (i. if it is near the surface % is less & if it is away then % is more), which I think gives wrong picture about bonding.
can u explain that?
Re: Applications for C-Scan Ultrasonic Testing
05/06/2007 4:51 AM
the c-scan is a kind of scan method use ultrasonic, which can form a flat picture of the detected object .
you can use it for your brazed material joint. but if you want to get more resolution picture you can use a x-ray apparatus.
Register to Reply 3 comments
cnpower (1); pc (1); techno (1)
