Previous in Forum: 1756 AB PLC - Input Bits Getting Latched   Next in Forum: RTD Checks Procedures
Difference Between Velomitor and Accelerometer?
12/20/2011 12:27 AM
What are the differences between velomitor/accelerometer and normal vibration probe?
Re: Difference Between Velomitor and Accelerometer?
12/20/2011 9:28 AM
Velometer measures velocity, accelerometer measures accelleration. A vibration probe may be mechanical, but it measures vibration.
12/20/2011 1:49 PM
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
12/22/2011 10:04 AM
An accelerometer generates a voltage signal proportional to acceleration (a = dv/dt). Bently-Nevada's Velomitor is actually an accelerometer with a built-in integrator circuit to generate a voltage signal proportional to velocity (v = dx/dt).
By contrast, a "normal" vibration probe such as Bently-Nevada "proximitor" probes generate a signal proportional to distance (gap) between the probe tip and the rotating machine's shaft.
To summarize:
Proximitor vibration probe: x
Velomitor probe: dx/dt = v
Accelerometer probe: d2x/dt2 = dv/dt = a
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Register to Reply 3 comments
lyn (1); SolarEagle (1); tonykuphaldt (1)
