Previous in Forum: Using Electronic Ballast Instead of Inductance?   Next in Forum: Why PF improvement capacitors are in Delta connected? y not in Star?
Effective Grounding and Bonding in Petrol Stations
12/20/2011 10:49 AM
Hi all,
since, i am serving as a electrical contractor for Petrol fueling stations, we are following unloading(product unload from tanker to underground storage tanks) earthing as follows:
All metal parts(unloading pipe and tanker lorry) have interconnected.
All metal bodies (both unloading pipe and tanker lorry) connected individualy to dedicated earthpits.
I want to know this procedure is OK, if not any better suggestion.
Pathfinder Tags: Bonding and grounding
Re: Effective Grounding and Bonding in Petrol Stations
12/20/2011 12:41 PM
You can use a clamp on connector to connect underground tank to tank truck or fuel nozzle before initiating pumping procedure, just to be sure....
12/21/2011 1:28 AM
Thanks for your reply
12/26/2011 2:13 PM
u may also use scully self proving grounding system for loading and unloading of hazardous chemicals.
search it on google.
We are using this system in our plant.
products mentioned by solar eagle also works fine.
Register to Reply 3 comments
Amanullah K (1); muditmah (1); SolarEagle (1)
