Previous in Forum: Welding Flanges on Pipes and Shot Blasting   Next in Forum: Steam Coil Design
Polishing H-Joint in Rectangular Pipe
04/30/2007 8:42 AM
There is a H-joint made of 1" square stainless steel tube. the H-joint is made after welding the pipes with tig-welding which have to be polished in hairline/Matt finish. Now, the problem is in cleaning the internal corners of the H while maintaining the flow of hairs in same direction.
Re: Polishing H-Joint in Rectangular Pipe
05/01/2007 9:44 AM
This one is a real problem.
How about more information such as;
What is the fabrication used for?
Media, Pressure and Flow?
Quantity need to produce? (This is important as some solutions could be too costly for a small production run.
05/01/2007 9:55 AM
Actually this piece is for showrooms and only the appearance matters. The direction of the hairline finish is to be maintained. We have even tried the pickling with gel but it leaves stains. Can anyone suggest the correct meathod for pickling 204 grade of stainless steel?
05/01/2007 10:27 AM
In that case, take it to your nearest Metal Plater's shop and they can give you any finish you want.
