Previous in Forum: What Kind of Script Does CR4 Use?   Next in Forum: Software to Find Plagiarism
AutoCAD, MS Word, and Mime Docs
04/30/2007 10:25 PM
How do I copy a sketch of design problem i need help with?
i have AutoCAD (DWG) and i can transcribe it to MSN WORD, but this server says it is a Mime doc. and won't let it load.
Any other methods?
Thanks,
Netmaker
Pathfinder Tags: Autocad design problems drawing
United States - Member - Go Tigers! Engineering Fields - Mechanical Engineering - Specialty - Mechanical Vibrations Fans of Old Computers - UNIVAC - Man I shoulda bought a Whirlwind!
Re: Need to send a drawn out design problem
04/30/2007 11:21 PM
With the AutoCAD *.dwg file open you can hold "Shift" and press "Print Screen" to take a screen shot of your sketch. From there, open MS Paint (or equivalent) and paste the screen shot. You can then save the file as a Bitmap or JPEG.
fm!
"Your theory is crazy, but it's not crazy enough to be true." - Niels Bohr
05/01/2007 1:39 AM
Thank you. That was easy enough.
netmaker
05/01/2007 4:09 AM
Why eat more fish cows are plentiful fish are getting scarce. I say leave the fish alone, and turn cannibal humans are two a penny.
05/02/2007 1:14 PM
It seems that the folks who sign in as guests are the folks who make dumb comments like this one.
"turn cannibal humans are two a penny".
Re: AutoCAD, MS Word, and Mime Docs
05/02/2007 2:13 AM
You can also select any or all of the drawing then Ctrl-C (copy) and Ctrl-V (paste) them directly into any MS program.
05/02/2007 2:49 AM
Try the command JPGOUT.
The file it creates can be inserted into Word doc.
05/03/2007 7:47 PM
Maybe if you can trascribe it to a "pdf" format (acrobat reader) and insert as an image in word it might help
Hope this will help..
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
Register to Reply 7 comments
Anonymous Poster (2); fattmaxx (1); Frank-Jazz (1); LaMarTEK (1); netmaker (1); user-deleted-5 (1)
