Previous in Forum: Double Acting IC Engine   Next in Forum: ASME B 16.34
13 comments
How to Eliminate Centerline Crack in SAW?
01/06/2012 2:52 AM
How to eliminate centerline crack in SAW?
Material: SA516-Carbon steel. 25 mm Thick.
Process:Submerged arc welding
Also inform that which element is responsible for cracking?
and which element is prevent cracking in weld bead?
I using metal powder in SAW process.
Re: How to eliminate centerline crack in SAW?
01/06/2012 4:25 AM
Check for the flux(moisture & reuse of unutilised flux during welding) you are using while welding, I too had faced the same thing some time before. That can also be because of ambient temperature. please do inform if you find this helpfull.
Good Answers: 29
Re: How to Eliminate Centerline Crack in SAW?
01/06/2012 10:45 AM
This is a thick piece of base metal!
1. Are you preheating?
2. What Joint Geometry is used
3. Single ot Multipass
4. If Multipass are interpass temps controlled
Suggestions:
1. Adjust Travel Speed (Slower?)
2. Increase Electrode Size while lowering Voltage
3. Increase Joint Angle
You will porbably have to find the correct combination of these things through trial and error. I suspect heat diferentals are your problem with "T" so large. Also; release from fixture as soon as practicable after completion of welding.
Si vis pacem, para bellum
01/06/2012 11:20 PM
How many runs 1 or 2? What prep is being used? Type of joint?
It is better to have people think you are an idiot, than to open your mouth and remove all doubt.
01/07/2012 10:20 AM
Are you sure it is not centerline segregration?
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
01/07/2012 10:30 AM
● Preheating is very necessary especially in case of welding materials with higher thicknesses to minimize and control the effect of rapid cooling of weld puddle due to rapid of heat transfer due to the huge of mass around the welded joint. Preheating requirement is as per ASME VIII-1, Nonmandatory Appendix R.
Note: Applying preheat can directly solve the problem of centerline cracking, where the sides of welded puddle start to solidify (due to rapid cooling rate) where the center of welded puddle remain in molten phase in which the shrinkage shall cause cracking at centerline.
● Also, interpass heating between every two welding passes is very essential. In addition to PWHT (if needed per code) is very essential as per ASME VIII-1, Table UCS-56.
● See the attached file for actual WPS & PQR (including preheat, interpass & PWHT) for welding of ASME SA516 Grade 70 using SAW for test coupon with thickness t = 14 mm which used to qualify welding of 2t : http://www.4shared.com/office/-nJs6I8E/WPSs__PQRs.html
01/07/2012 1:28 PM
Welding Process (es)
SMAW + SAW ( For Non Impact Application)
Type (s)
MANUAL + MACHINE
Supporting PQR No
: PQR/86A/09 Date:10/02/2009
JOINTS (QW-402)
Joint Design
As per Production Weld
[ Typical V groove, Root Gap 1 to 3.5 mm ]
Backing Material (Type)
Backing
With Backing
Metal Non-fusing metal
Retainer
NONE
Nonmetallic
ü Weld metal.
BASE METALS:(QW-403)
FILLER METALS :(QW - 404)
P. No. & Gr. No.
P No. 1 Group No. 1,2
To Process
SMAW
SAW
P. No. & Gr. No.
P No. 1 Group No.1, 2
F-No.
OR A-No.
1
1
Specification Type & Grade
To Spec. No. (SFA)
5.1
5.17
AWS No. (Class)
E 7018
EH 14
OR Size (mm)
3.15, 4,5
3.15,4, 5
Chem. Analysis & Mech. Prop.
To Electrode-Flux(Class)
NA
F7A2-EH14
Chem. Analysis & Mech. Prop. -- Alloy Element
NA
NONE
Groove Fillet Consumable Insert
None
None
Base Metal Thk. Range (mm)
5 to 44
All
Deposited Weld Metal Thk.(mm) Groove
12 Max.
32 Max.
Other ·
Each layer thickness less than 12 mm
· QW403.13 - NA
Fillet
All
All
POSITION : (QW-405)
Other ·
Flux is Neutral
· No use of Recrushed Slag
· No use of Supplemental
Positions (s) of Groove
All for SMAW
Flat for SAW
Welding Progression
Uphill when vertical
Position (s) of Fillet
All for SMAW
Flat for SAW
PREHEAT (QW-406)
POSTWELD HEAT TREATMENT: (QW-407)
Preheat Temp. (Min)
1000C
Temperature Range °C
NONE
Inter pass Temp. (Max.)
2500 C
Time Range
NONE, QW407.4 - NA
Preheat Maintenance
NONE
Others :
ELECTRICAL CHARACTERISTICS (QW-409)
GAS :(QW-408)
Current
DC
Gas (es) % Composition Mixture Flow rate LPM
Amps (Range)
80-250 A for SMAW
250 to 600 A for SAW
Shielding
NONE
NA
NA
Polarity
DCEP
Trailing
NONE
NA
NA
Volts (Range)
18-25 V for SMAW
20 - 30 for SAW
Purging
NONE
NA
NA
Tungsten Electrode Size and Type
NA
Mode of Metal Transfer for GMAW
NA
Electrode wire feed speed Range
NA
TECHNIQUE: (QW-410)
String or Weave Bead
String / Weave or Both for SMAW
String for SAW
Orifice or Gas Cup Size (mm)
NA
Initial and Inter pass Cleaning
Brushing and / or Grinding
Method of back Gouging
Grinding
Oscillation
NA
Contact Tube to Work Distance (mm)
NA
Multiple or Single Pass (per side)
Multiple
Multiple or Single Electrodes
Single
Travel Speed (Range)
As per table given below
Peening
NONE
Other
Use of thermal Process - NONE, Electrode Spacing - NA
Weld Layer Process Filler Metal Current Voltage
Range
Travel speed
Range
[mm/min]
Remark
Class Dia- mm Type
Polarity
Amp.
Range
Root & Hot Pass
SMAW
E7018-1
3.15,4
DCEP
80 - 250
18-25
100 to 160 for 3.15dia
120 to 180 for 4 dia.
Rest
SAW
EH14
3.15
DCEP
250 - 400
350 - 475
450 -- 600
20-30
400 to 500 for 3.15dia
450 to 550 for 4 dia
500 to 600 for 5dia.
After Back chip (Back gouging)
Rest
SAW
EH14
3.15
DCEP
250 - 400
350 - 475
450 -- 600
20-30
Try this one if it helpsssstr
Good Answers: 18
01/08/2012 11:12 AM
In thick section welding of SAW process,cracks may appear due to one or more of the following reasons.
a) Rapid cooling of the weld deposit, b) Heavy restraint in the joint c) Excessive dilution of weld with parent metal, resulting in pick up of carbon and other alloy elements and consequent hardening, d) excessive hydrogen in the derived from moisture , grease, oil etc.
If the cracks are due high dilution,Welding procedure must be modified to reduce the metal penetration through,
1) Increase the electrode size (you have not indicated the size) to 4.00 mm or so.
2) Deposit first pas with SMAW- E 7018- 4.00 mm and later with SAW.
3) The bevel angle be ensured to 600 minimum to ensure the width is greater than the depth of the bead.
4) Abnormal bead shape is also sighted as cause of cracking.i.e.,
a. Cracking could be due to large width and low depth of a bead.
b. Cracking could also be due to small width and high depth ratio, i.e., we call it as a 'bead factor' and W/P >1. (where W is bead with, P is total penetration) If it is less than 1,due to stress concentration and other factors a center line crack is sure to appear if not at the time of welding, but it can occur in service also.
Trust above details will help to overcome your problem.
sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
01/09/2012 1:17 AM
I am using...
Plate Thik.= 25 mm (SA516 Gr 70)
Code: ASME Sec- IIC , All Weld Assembly
Process :SAW
Wire Dia: 4 mm (EM12k)+ Metal powder addition seperatly ( 95.5 % Fe powder + 4.5 % alloy powder)
A=550 , V=30, TS =50 cm/min.
which element is better to add with powder to prevent cnterline crack?
pls reply....
Good Answers: 18
01/09/2012 10:05 AM
Your weld parameters are OK. May be stick out could be 40 to 60 mm. Metal powder addition helps to increase the volume of weld bead and reduces the no. of layers.
As mentioned earlier, please check the bead width to depth ratio.
Second point is check for basicity of the flux. Basicity index is very important for agglomerated fluxes and it is the ratio of basic and acidic oxides.It is kept in between 2.2 to 3.2.and higher the basicity, lower are the oxygen and sulphur contents of the weld metal and higher its notch toughness. More basicity makes the slag removal difficult.
Hence check up the batch test certificate for the values. If details.are not mentioned, ask your manufacturer for same.
Sulphur is one element which may cause grain segregation (center line cracking) during the welding and neutralized by additional ratios of manganese.
But in your case we do not expect this problem if the wire & flux manufactures are one and same. They take care of the end chemistry for every batch production.Do not mix different wires & fluxes.
sridhar.
01/10/2012 12:39 AM
Sir,
I have chcked Chemistry of my above mention weld.
it contain,
C=0.004 apprx.
Si=.53, Mn=1.75
B=>0.0017
Boron % is more and Carbon % is low comparative to other weld chemistry.
So what will be the reason for crack?
Also if u have any knowledge about metal powder addition in SAW, pls guide me or send some litrature about it.
Good Answers: 18
01/12/2012 6:14 AM
We have given enough hints for the said problem. Check up the bead factor as detailed earlier. The cracks can also appear if the joint is under contraction stress or if the joint is under restraint.Check up the bevel angle, joint fit up. If the cracks were seen in the first weld pass remove them before proceeding with further passes. Check up and maintain proper preheat and inter pass temperatures.
The chemistry is OK and cracks do not occur due to meal powder additions. Boron is a trace element only.
sridhar
01/14/2012 8:26 AM
Check for storage condition of your flux & metal powder - any humid environment could lead to moisture absorption and resulatnt H2 in to metal bead- cracking.
Check also for your plate centreline defect/segregation if any at weld area where it is craking in weld . - Macro-examination of cross section by aid etching will reveal the defect if any , or go for micro-structuural examination .
SK Hegde
Good Answers: 18
01/20/2012 10:49 AM
A small correction from my end. Examination of the defective area (cu out a small portion - 10*10*25 mm size or as required by the code of testing) will help. Analise it for its Micro structure, hardness etc after polishing and enlarging the grain structure through a microscope.This could be done at any analytical testing lab..
This will help to conclude the reasons for cracking.
sridhar.
Abdel Halim Galala (1); Anonymous Poster (1); neerajkumar (1); PMoon (1); ronclarke (1); santhosh52 (1); sojitraanil (1); son77jai (1); SRIDHAR (4); techmad (1)
