Previous in Forum: Graphic Designers   Next in Forum: Technology supplier from China
How Does a Rock Crusher Work?
01/08/2012 10:42 PM
How does a rock crusher work? First, let's learn what a rock crusher is.
A rock crusher is a device used to crush rocks into smaller pieces, usually for gravel or some other road or building application. Most rock crushers have a hopper at the top -- a container which holds the rock above the crusher and uses gravity to feed it in. Alternately, rock crushers can use a belt drive to continuously transport the rock into the crusher. At the bottom of nearly every type of crusher is a hole. Once a rock has been pressed into small enough pieces to fit through the hole, it exits the crusher either onto, a conveyor belt, into a bin or onto a large pile. In some cases, one rock crusher may feed directly into a second one, crushing the rocks up into finer and finer particles in two or three stages.
