Previous in Forum: pharmaceutical raw materials importing   Next in Forum: Hydraulic power in a renewable energy plant
What is a Solar Water Heater
01/12/2012 10:35 PM
SPP offers complete solar collector installation-ready solar water heating system kits, as well as a wide range of individual components including collectors, tanks, heat exchangers, pumps, controllers, valves, fittings and more. SPP also provides free training, engineering and design assistance to it's customers. Below, see some of the things that make the SPP-brand collectors the top choice for both commercial and residential solar water heating systems.So what makes the SPP-30 the worlds solar accessories best and most efficient solar water heater collector? Our people do. The goal was to make a more durable, less costly, and easier to install collector that would outperform the competition in its solar thermal collection efficiency.
We succeeded. Read on to see a few of the things we changed.A solar heater works via the solar panels and a solar water storage tank. There are two basic types of solar water heaters and they are known as active and passive solar water heating systems.The active system uses circulating pumps and controls like a traditional water heating system, while a passive system does not have these solar water heater tank welding equipment things. Although passive systems are not as expensive as active systems, and are more reliable and often last longer, they are not as efficient.One of the most important things you should have if you want your solar water heating system to function properly is a well insulated storage tank.Solar water tanks also have an extra outlet source and inlet source.
You can get two-tank solar water heating systems or one-tank solar systems. Before the low pressure solar water heater goes into the ordinary water it is first heated by the solar powered water heater in a two tank system. Both the back up heater and the solar water store are combined in a one tank system.Whatever kind of solar water heating system you have installed, there are other things that you can do if you want to lower the cost of your water heating bills and run a 'greener' home - this is especially relevant to people with an LED down lights active system that requires back-up. Some energy saving devices need to be put in place when your solar hot water heating system is installed.Solar water heaters are an alternative to the more traditional immersion heaters and hot water tanks.
Good Answers: 62
Re: What is a Solar Water Heater
01/12/2012 10:43 PM
Stop - you are not posting in our commercial section!
01/12/2012 10:52 PM
This is your what your brain says: "Stop - you are not posting in our commercial section!"
This is what zhenxinfei's brain says" 你是白痴,我會騙你。
Good Answers: 62
01/12/2012 11:32 PM
My translator blew up, or should I bother?
But I'm not un-aquainted with futility
01/12/2012 11:41 PM
Don't bother. It wasn't that funny.
Register to Reply 4 comments
