Previous in Forum: Voltage of Fuel Sender/Float   Next in Forum: Petrol Leak
Ford Bantam Fuel Gauge
01/13/2012 8:14 AM
Good day Friends. I drive a Ford Bantam 1.3i (Rocam engine). The fuel gauge was working perfectly well until I filled the tank full to capacity (used to just fill enough until this day, bought the vehicle second hand). Since this recent fill the gauge "collapsed", with the low fuel indicator light permanently on. The vehicle has clocked over 300km and the gauge has not woken up once ever since.
I need your advise as to where I can look in order to correct/repair this problem, please
"Intelligence is more important than knowledge" Einstein
Re: Ford Bantam Fuel Gauge
01/13/2012 8:22 AM
The float has taken on fuel and will no longer "float". It now sits at the "out of fuel" location.
Repair or replace.
01/13/2012 10:07 AM
Good Answers: 19
01/14/2012 1:04 AM
Good show. Care is also called for in removing the old sender, as this access is often in a very dirty location, like the floor of the trunk.
01/19/2012 3:24 PM
Thanks friends. I will follow your suggestions in repairing this problem. I just need to drive a few more kms to reduce the fuel in the tank...I had to take out an Isuzu KB some time ago while three quarter full and it was no child's play.
Good Answers: 123
01/13/2012 2:55 PM
Do not use a match to look at the float.
Bob
01/14/2012 8:58 AM
The vehicle may have a CVR (constant voltage regulator) just for the fuel gauge. I have had these fail although not in the past 30 yrs. If you remove the sending unit check it with an OHM meter as you move the float the reading should vary accordingly. If possible check the voltage to the gauge if there is any. This is a good start.
Register to Reply 6 comments
bob c (1); bubbapebi (1); lyn (1); Maggie1 (1); roy hammy (1); SolarEagle (1)
