Previous in Forum: High Speed Valves   Next in Forum: How to Reset A Danfoss Temperature Control To Be Getting Realistic Readings?
Transmitter Calibration
01/19/2012 6:36 AM
if transmitter
LSL=0
USL=2
LRV= -1
URV= +1
so can we calibrate the transmitter in this range ?
Re: transmitter calibration
01/19/2012 6:40 AM
Yes, we can, though it would help if we knew what we are talking about.
Good moaning!
Good Answers: 176
Re: Transmitter Calibration
01/19/2012 10:42 PM
Common instrumentation acronymns are:
LRV means Lower Range Value
URV means Upper Range Value
LRL means Lower Range Limit
URL mean Upper Range Limit
What does LSL mean?
What does USL mean?
01/20/2012 12:23 PM
LSL LOW SCALE LIMIT OR LRL LOW RANGE LIMIT
USL LOW SCALE LIMITE OR URL LOW RANGE LIMIT
BOTH MEANING IS SAME
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
01/20/2012 7:12 PM
In my experience, "LSL" means "Lower Sensor Limit" and "USL" means "Upper Sensor Limit". If the sensor cannot register negative values, then you cannot set either range value to a negative number.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Good Answers: 176
01/20/2012 12:39 PM
Well, a LRV (value) of -1 is less than zero. -1 < 0
If the lower limit is zero, how can a value less than zero be accomodated?
01/24/2012 4:27 AM
With the help of Multi Function Calibrator - Calibration can be done in either Lab or in Site .
Good Answers: 176
01/24/2012 11:23 PM
Check out your associate's (alter ego?) identical question, with far more information on the situation in this thread on Control.com
http://www.control.com/thread/1327385512
Register to Reply 7 comments
Crabtree (1); Iris (3); mr technician (1); sivaa (1); tonykuphaldt (1)
