Previous in Forum: instrument farmulas   Next in Forum: DC Drive Digi Master12
Control Valve
01/20/2012 2:27 PM
can you explain cv,benchset and charateristic for control valve....
Thanks.
Re: control valve
01/20/2012 2:28 PM
No, can you?
OK, just this once.
Control valves - Wikipedia, the free encyclopedia
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: control valve
01/20/2012 7:23 PM
Cv is the "flow coefficient" of the valve, used to calculate how much fluid will pass through given a certain amount of pressure drop.
Bench-set refers to the calibration of the valve following a rebuild: specifically setting the spring tension and the stem travel.
Characteristic refers to the function of Cv versus stem position.
I would also recommend any of the literature available from Emerson (Fisher valve corporation) at:
http://www2.emersonprocess.com/en-US/brands/fisher/Pages/FisherValvesInstruments.aspx
Probably the best single book for you is Fisher's Control Valve Handbook:
https://www.pacontrol.com/download/Emerson-Control-Valve-HandBook.pdf
Out of curiosity, which school are you studying in? Many of the questions you have posted on CR4 sound like homework questions for a school.
CR4 Admin: deleted broken link
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Re: control valve
01/20/2012 8:23 PM
Nice job.
Register to Reply 3 comments
